Cannot get the phone to start
My HTC Desire pay as you go phone has suddenly gone blank. No screen, nothing. I am away on holiday and rely on this to call my elderly mother. Any advice welcome.
Hi,
Try the following:
Remove the battery, wait for about 10 seconds, then reinsert the battery.
Here is a video that shows how to remove the battery. The battery only has connections at one end so when you replace it make sure the terminals are in the correct position. Also don't miss it in the video the battery removal is complete within the first 27 seconds .
See if it will charge/start now.
If not try performing a factory reset.
Be aware a factory reset will erase all your downloaded apps and user data . It will restore your phone to a factory default condition. It will be like when you first bought it.
To reset your phone:
Be patient, it takes a few minutes.
If you cannot perform a factory reset due to the phone not responding, unfortunately and obviously the phone is faulty. Perhaps a professional phone repair service may be able to repair it. Ask for a quote first.
If your phone is still under warranty, contact the manufacturer's customer service section regarding a warranty replacement.
Thanks, removing the battery worked!
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 5
All Time: 96
2 Comments
Hi,
Do you get any indication (charge light, symbol etc) at all on the phone when you connect the charger to the phone or if you connect the phone to a USB port in a working PC? Can you try a different compatible charger or USB cable?
by jayeff
No indication at all. Cannot connect to PC but have tried 2 chargers.
by Hilary Patterson
