Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
197 Questions View all
Charging area got slight water damage, no charging
iPad4 - I had recently let my iPad get slightly wet for a few hours on the bottom in about a centimeter or half an in. of water. Everything works fine, but it won't charge any more. It did charge for a bit after being wet, but eventually just stopped charging. I think something is corroded on the charging connection hardware. Would I be able to fix it with replacing the Lightning connector?
iPad 4 Lightning Connector
Thanks for your help.
iPad 4 Lightning Connector Image
Product
$19.99
Add a comment
1 Answer
Chosen Solution
Most likely. iPads are kind of a lot of work to get into though.. At any rate it's most likely just a new lightning dock
Score 2
Comments:
Thank you for your time.
by
Add a comment
Add your answer
Daniel Furey will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 52
