Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Question Closed
Multiple questions regarding iPhone 6 repair.
Hey!
Is it possible to find out which of the part on my logic board that is broken due to waterdamage?
Can I transfer a battery from one iPhone 6 to another?
Can I use screws from an iPhone 5s on an iPhone 6
I've got this "Screw hole distribution" for iphone 5, and I were wondering if there is something similar for iphone 6 and above?
Add a comment
1 Answer
Chosen Solution
1) Yes, by testing components with a multimeter. I would read up online before doing so to prevent blowing things on the board.
2) Of course you can, as long as it's an iPhone 6 battery it will be fine.
3) Some of them you can, you would have to look and see which are the same screws/sizes. I would just buy new screws as they're really cheap.
4) There will be screw sheets for the iPhone 6. Something like this?
http://www.ebay.co.uk/itm/iScrews-Repair...
Score 1
3 Comments:
Thank you very much!
1) I will do that first thing tomorrow!
2) Nice, I thought pulling the adhesive tab kind of destroyed the battery(??).
3) I have bought 3 set of screws for iphone 5s so I've got for a while.
4) I don't want a sheet, I have a tendency to bump into the table I'm working at and creating a massive chaos.
by
They have holes so it would be impossible to bump and knock them out of the holes. You won't ruin the battery if you pull it out perfectly. I would just get a new battery personally.
by
That takes time and money, and I've got neither, this is just two broken devices I've bought cheap for parts, but I thought I could try to replace the water damaged Logic board into the iphone that has nothing but beauty damages(and a broken touch ID ribbon). But thank You for your help! It means a lot
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 74
