The Canon Powershot A1000 IS features a lens with 4X optical zoom and a focal length of 6.2mm to 24.8mm and maximum f-stops of f/2.7 and f/5.6.
6 Questions View all
Question Closed
Can't close battery cover, because of small plastic broke
So this little plastic hole just broke, don't know how to repair that. It's annoying, because for this time I'm using ducktape, but it's not practical, when you need to pull of sd card.
1 Comment:
Are you referring to the clasp that holds the battery cover down?
by
Add a comment
Hi. Probaly u will need to replace entire housing of camera.
Add a comment
Do you have the little plastic hole with you? If you do then super glue it back on.
Add a comment
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 6
All Time: 176
