Slow rotation when calibration, then never gets working
Hi everyone, just bought a used ARC team Modded G27, that has many problems.
I post a link to a video as explaining it in words gets long
https://goo.gl/photos/tHGf3QA3Bzcccdw56
Briefly the wheel is recognised (every button and potentiometer and pedals and shifter) but the calibration part of force feedback happens slowly, then interrupts, the heel never gets hard to turn, and basically it's useless....
Resoldered DC cable, checked it ha good insulation and voltage is 41.6.
Any idea of where to start troubleshooting?
Aggiorna (23/01/2016)
I found a piece of manual online https://www.yumpu.com/en/document/view/1... where it states that the voltage in the mod should be 40.5, so 41.6 should be fine......
Maybe I could fully dismantle the unit and test component by component with a tester if resistances and voltages are fine. I should anyhow need a bit of help doing it.. and maybe a probability assessment of what is probably wrong so I could not fall in Murphy's law and let it for last...
Hi,
Just curious. Your voltage reading is that correct? Have read that ARC mod was to increase power to 48V, http://www.racedepartment.com/threads/ar... Is yours maybe a little low then. Incorrect power can cause all sorts of funny problems. Some things may work others not, it depends then on component characteristics, whether they work as designed or not at a lower voltage..
by jayeff
