Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
210 Questions View all
Cant register network/no signal, after 'water damage'
Just recently dropped my s6 edge into a river, worked for awhile then switched off. Pulled apart my phone, alcohol cleaned it and replaced my battery, now all is working except my phone signal. My sim card works in another phone so i'm questioning what part do i have to make certain is ok apart from the antenna cable and how i can go abouts testing it out. I will reseat the antenna cable although i would like to know what other antenna associated parts i have to play with. I know its not software since i already checked that. Thanks!
Score 1
Comments:
I have the same problem, did you find a solution for it?
by
Add a comment
1 Answer
Most Helpful Answer
I can say that you have to clean very carefuly the board. Alcohol is good but i will prefer Isopropanol or isopropylalcohol. After clean you can check this parts below and two cables between them:
Score 1
Comments:
thank you! I cleaned the parts, but now i can only use GSM or 2G only on mobile network settings. When i choose another option i do not lose connection with the provider or the sim, but i cannot make calls, go on the internet or send a text message. I checked the APN from the provider, my IMEI number is not corrupted or something.
Like to hear some suggestions
by
Can you post a clear pic from the charge connector flex cable?
by
Add a comment
Add your answer
KmkZ will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 44
All Time: 4,218
