Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Questions View all
Touch function does not work on the bottom of the screen, why?
I have replaced the part and the installation proved to be easier than I though, however once I turned the phone back on, the touch function does not work at the bottom of the screen, I cannot hit the space bar and the lower letters...nothing...what do I do?
Score 9
Add a comment
Most Helpful Answer
If the part that you just replaced is the digitizer panel
that means you might have faulty digitizer panel.
But before jumping to conclusions,i would open the phone again,
and i would disconect the cables #1 #2 and #3,and i would take out the lcd+digitizer panel assembly and set it aside.
Then i would check with a magnifier mirror,the contacts on the flat cable
#1 which is the one responsible for the digitizer panel and then i would take one of those aerosol spray cans,used for cleaning of computer keyboards and i would blow a few jets of air in the conector where the flat cable #1 goes in.That's the special one that you have to lift a small
piece of him to be able to put the cable in and then you have to slide it back down to secure the cable in place.
It might be a speck of dust or something small inside there that doesn't allow a good contact and then you don't have the bottom of the screen working,like you do now. Good luck.
Score 2
Add a comment
I believe you have a faulty piece of hardware. Maybe it was messed up during transit, or maybe you just bought a faulty one.
Add a comment
I had this same problem. Multiple restores, cleaned and reseated contacts, to no avail. I decided to try downgrading to 3.1.3, and after downloading an ipsw, trying to restore with it and getting an error, I restored to 4.2.1 without issue, bottom working perfectly. I'm not offering this as a tutorial as I'm mainly an Android guy, but it definitely worked for me.
Cheers,
tabormeister
Add a comment
I have a nexus 7 and when I type it jumps to the next letter
Add a comment
Add your answer
stepharbour will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 28,242
