The Samsung Galaxy Note II is a smartphone noted for its combination of a large display and software optimized for an integral self-storing stylus.
211 Questions View all
Samsung Galaxy Note 2 won't start
Hey everyone, i have a Samsung Galaxy Note 2 GT N7105 and i had the usual start up screen with the samsung logo, then the phone didn't turn on—it stayed on the logo
i could hold the power button to restart it and it would just come back and wouldn't start up so i had a look on the internet for a solution and the said taking the battery out and holding the power button (aprox. 40sec) so i did, put the battery back in pressed the power button and nothing not even the samsung logo, even when plugged in the battery light (led) isn't on either
so i tried starting it up in the recovery and the other modes but nothing works, it's just dead... i have tried to charge the battery manually for a bit by cutting a cable and holding the positive and negative cable (nude) by hand and putting the battery back in and it didn't work. i have tried various cables/docking part, tried on the pc by usb different plug with and without the SIM and memory cards booting it up and nothing is working.
please help, thanks a lot in advance, i have no more ideas and the internet doesn't either.
Score 4
1 Comment
Id like to know some more information.
1. Has the phone been dropped, or exposed to water
2. These cables you hooked up to the battery, what were they connected to?
3. Have you tried alternate chargers and batteries? And is your charger genuine samsung. As alot of newer samsung phones are extremely picky and wo t charge from generic ones consistently
by
Add a comment
Most Helpful Answer
Hi. Have you tried to factory reset it? You can follow this guide - http://thedroidguy.com/2015/06/how-to-fi...
Score 3
Add a comment
Ok,if your using your phone while charging(just like me).Well stop,the more you use it while charging,it may cause the Battery to be damaged.While plugging the charger to the Phone it works but may cause to shutdown because the charger and the phone is sensetive.The best thing to do is buy a Replacement battery.
Add a comment
Add your answer
lewis will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 29
All Time: 7,439
