The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Question Closed
Front Glass/Digitizer Touch Panel not seated.
"My first attempt at a repair. I wasn't able to get the Front Glass/Digitizer Touch Panel completely down inside the plastic bezel. Is there a tape or something to wrap around the outside to hold it down that looks OK? This repair is for me not a customer. I just want to keep the glass from breaking as it sticks up ever so slightly.
Add a comment
1 Answer
Chosen Solution
If you start putting pressure on the screen by taping the edges you will start having issues like ghost touching, and more than likely will break the screen again. Plus without those edges being under that plastic edge that screen is going to start lifting. Best bet do it right, remove the screen, re tape and put the screen inside the plastic edge like it was designed to do. When taking off the screen use lots of heat and go slow!!
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 59
