Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1496 Questions View all
iPhone won't turn on
So I had a friend that dropped his phone in a pool and I put in a new logic board and battery. The phone worked fine, since all damaged parts were removed. Then one day I shut it off, and it wouldn't turn on. I lifted the logic board off the battery, put it back on, and it booted up fine. Now I turned it off again, and even after lifting the connectors apart, it still won't turn back on. Any suggestions on anything I should try?
Add a comment
1 Answer
Chosen Solution
If you can't get it to turn on by plugging the USB cable into your computer, you need to replace the dock connector.
Add a comment
Add your answer
Neil will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 997
