Model A1502 / 2.4, 2.6, or 2.8 GHz dual-core Intel processor / Released October 2013
552 Questions View all
Screen with purple/green spots for~20 mins after turning on.What's it?
When I turn on my mac sometimes has really unusual colors for a while (around 20 minutes) before coming back as usual.
what generate this problem? it is possible to fix it or I need to change the screen?
PICTURES of the screen: www.valutami.com/mac.html
Score -1
Add a comment
1 Answer
Chosen Solution
Sounds like a screen problem indeed.But before doing a screen replacement,take a quick step and connect the laptop to an external monitor using the HDMI or the thunderbolt in case you have a compatible screen.IF the external monitor works fine after time then it's the screen ready to be trashed.If you have a similar problem something is wrong with the logic board or the graphics card chip in the board.
Just in case,test the connecting cable of the internal screen for loose connection.Open and close partially the lid and rotate-carefully-the laptop to see if there is any similar problem of decolorization.
If all the above indicate nothing,then you can be sure that your screen in guilty!
Hope it helps,
John
Score 1
Add a comment
Add your answer
famgiordano will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 3
All Time: 1,862
