Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Is it possible to replace a broken fan connector?
I was trying to replace my fan on my MacBook pro 13" late 2012 and accidentally ripped off the connector for the fan to the computer. Is it possible for me to buy a new connector and connect it myself?
1 Comment
I have also popped the fan connector... my problem is that i am missing one of the four solder pads that allow the cable to connect to the mother board. Sorry the mother board is missing one of the solder points that allow for the connection between the fan connector and the motherboard.
I tried to chip off a small piece of soldier and managed to soldier all the 4 pins to the mother board. My problem is that when running the mac fan control my rpm's for both fans are over 7K...
Im afraid when soldiering the pins i held my iron too long on the plastic and melted the solder inside?
Should i get a new fan? any suggestions will be most helpful
thank you for your time
by
Add a comment
1 Answer
Chosen Solution
Yes you can get them on ebay for 5 bucks . If you don't have solder iron or skills, well then get one! And practice on a old motherboard to get the feel . Buy 2 connectors , the connectors are plastic so be careful not to be on them long with the iron , it won't do anything but melt the connector and you have to clean your iron , so be quick with solder to the pads.
3 Comments:
Thank you!! the fan will still turn on with the computer? I'm just a little confused how the new connector will receive power given I ripped the old one off.
by
Are you missing any of the 4 solder pads that the connector ripped off of ?
If not you just solder the connections onto the solder pads. Let me put it like this regards to the receiving power. If you took and pulled the connector off the fan wires and soldered them directly to pads without the connector they would still work given the solder pads where still intact and ...even if they were'nt you could still run a jump wire to it's next power point.
by
Oh okay that makes perfect sense! The four solder pads are still there. I would upload pictures but it seems I can't on safari mobile. Thank you so much!
by
Add a comment
Add your answer
James A will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,929
