A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
185 Questions View all
Question Closed
Screen skipping rapidly from one screen to another. Tried reset.
My LG g2 screen jumps from one app to another so fast I can't choose anything. Doesn't do it if it is charging.
Add a comment
1 Answer
Chosen Solution
Hi,
You say it doesn't do it when charging. Do you mean when it is on and working with the charger connected or off with just the charger connected?
If it works normally with the charger connected and on it indicates that your battery is failing and needs to be replaced.
If it doesn't work normally with the charger connected, it indicates a problem with the phone, possibly a faulty digitizer.
You say you tried a reset. Did you mean a Factory Restore (also known as a 'hard reset')? If so, again it points to a hardware and not a software problem.
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 75
