Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
Tried to repair front panel using instructions, display won't work?
My dad and I just tried to use the guide to repair the cracked screen on my iPhone 3GS. We did everything correctly (minus one screw) but now the phone turns on but doesn't display anything.
Anyone else have the same problem?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
I am assuming you mean that you tried to replace the broken glass and digitizer right? Or you replaced the LCD as well? The glass is on top, the digitizer is under the glass glued on to it and the LCD is underneath that.
Make sure your LCD is properly connected to the logic board. Carefully push it down until it snaps into place. Then try holding down the sleep button and the home button at the same time for a few seconds.
Also if you didn't turn off the iphone before doing the repair you might of damaged the logic board. Or you might have damaged the LCD as well.
Add a comment
I had to change it in my Iphone 4 and I broke the cable of the LCD screen it's very sensitive.
Add a comment
Add your answer
lbusser will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 509
