The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
No signal after replacing battery, battery drain with SIM
I have an 8gb A1203 and just replaced the battery. I get the "no signal" message after booting up. It will stay like that forever. If I turn airplane mode on then back off, it changes to "searching...." and stays like that till the battery drains and the iPhone shuts itself off. With a fully charged battery, this happens in less than 15 minutes. I have verified that the SIM is good in another phone. The battery seems to discharge normally when in airplane mode or the SIM is out of the phone. I have tried resetting the network settings several times and verified that the antenna connections are seated properly. I don't know what else to try. Please tell me I have not converted my iPhone into an iPod touch!!!!
Score -1
Add a comment
Chosen Solution
it sounds like an antenna problem. if the phone can't get a signal it uses loads of power searching. i'd go back and check again.
Score 1
3 Comments:
I have rechecked the antenna connections with a magnifying glass twice. Everything looks good. I tested the continuity of each of the cables and they are good too. I re-flashed the phone and re-unlocked and jail-broke and I am getting the same symptoms.
by
i'd try reseating all the antenna connections again. i know its tedious but sometimes its not obviously out of line. otherwise it could be the wires themselves that are damaged.after that? i'm not sure. sorry i couldn't be of more help.
by
I took it apart and reseated the antenna connections. I get the same problem. Wifi and BT work just fine. Do they use a common antenna or does each system rely on a different antenna? I am at my wits end here. Any other suggestions are appreciated. Thanks
by
Add a comment
I had the same problem after doing a battery replacement on my 2g. I tried tightening the middle screw down at the bottom of the metal housing where it attaches to the chassis a little more. This screw holds one of the antenna connector wires in place and I think that is what did it.
Score 1
Add a comment
Add your answer
Matthew will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,915
