Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1959 Questions View all
replaced dock-connector didn't fix my 3GS
My iPhone spent 24 hours in a river! The dock-connector was also damaged during the accident I had causing the phone to go into the river. It almost worked yesterday, white Apple, battery pic but not charging (just red vertical stripe at LH end) I even reached my home page a few times. Also had voice control window, but it wouldn't connect to my carrier. Today however I can't turn it off, and when I try to do that I just get a bright white screen, completely blank white, which dims when left untouched :-(
Score 1
Comments:
Thank you for your suggestions, but I'm afraid I am giving up now. I have already spent hours trying to recover this iPhone, starting with straight after my accident, I fell crossing a cliff-face and cracked 2 ribs, the iPhone shot out of my pocket at the point of impact; I didn't know where it had gone and I spent at least 6 hours cutting blackberries looking for it before I discovered it in the river next to the blackberries.
Apple have offered to replace it for 170€, I can't afford to waste any more time on it; I've had enough !!! But thanks, it almost made it, incredible when you think it had been lying on the bottom of this river for about 26 hours.
And yes, I pulled it all apart, pulled out everything except the battery; dried everything thoroughly for 10 days before I turned it on after installing the new Dock-Connector; the old one had taken a hit and the plug was all bent.
by
I should also add that I had for hours on the screen, before I saw my home page and startup picture (custom) the pic of a USB plug-->iTunes, but iTunes refused to recognize the iPhone. I tried all the steps on the Apple site for restoring and getting iTunes to see your iPhone, but *nothing* worked. Then I had the short period where my hopes skyrocketed, my home page appeared, I went into the iPod app but none of my music (at least 18GB's worth) was there. The the phone died, froze, wouldn't switch off anymore, then the white screen appeared and is still there.
by
Add a comment
Most Helpful Answer
I'm amazed that you recovered it after 24 hours in a river!
You should open your iPhone using this guide. Once you're at a step where you can see the logic board, you should use some strong isopropyl alcohol (90%+) and a soft brush to remove any white-ish residue you see. Let the device dry <thoroughly> to make sure all liquid is gone (this will likely take a day or two in a warm, dry place if the device is opened up. Putting the iPhone in a bag of rice can also be useful at this point.) When it is dry, put it back together, and you will have your best chance of it working.
If you do all this and it is still behaving strangely, come back and update this question with the symptoms, and hopefully someone can diagnose what's wrong.
Score 1
Add a comment
did you strip the thing down and dry it through? i assume, you did.
i would also try to swap the battery. it will almost certainly be shorted...
Add a comment
I've also done this procedure with no succes. But mine wasn't dropped in the river. But i saw that one of the inner labels where pink so i guessed it was once dropped in water. So i've bought isopropyl alcohol(96%) and washed it good and brush it gently. i've asumed the battery wasn't working soh i bought a new battery. when i got the battery it charged for a whole day with no succes. So i've again searched for answer and came upon a solution on ifixit that maybe replacing the dock connector might work soh i've done that also. I've installed the new dock connector it showed sings of life(the screen flashed 3 times with apple logo) and i though it was a problem. So i disconnected it from the power source(wall charger), when i plugged it back in no screen display.
i was wondering what might this be
Add a comment
Add your answer
raglan6 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 960
