Released September 2013, identified with model number T100T. 2-in-1 portable with Quad core Intel® Atom™ processor and 2GB of RAM.
80 Questions View all
Why my device doesn't power on, blinks white led 6 times only?
Hi,
I brought ASUS Transformer T100 from USA almost 5 months ago. It was working perfectly since yesterday. I left it on charge at night and when i pressed power button in the morning it did not turned on but i noticed the led light near power button flashes white 6 times. I searched it over internet and applied some reset tips(pressing volume down + power, home + power) so on for about 1 minute but nothing worked. Could you please advise what is going on with my device. I am really getting frustrated now.
Many Thanks
Manol
Score 1
2 Comments:
Battery is all good and charging. 1 quick question, if i disconnect the battery or harddrive will it put it back on normal mode?? I dont have any prior experience of messing with laptop or pc. :-)
by
battery? Bios battery not really (it will reset your BIOS) but if you disconnect the normal one there shouldn't be problem and if you remove HDD and put it back together it shouldn't be a problem either, but don't forget to wear ESD strap
what do you mean with "normal mode" ?
"I dont have any prior experience of messing with laptop or pc. :-) "
hey that's better than taking it to repair center and paying at least 20E
(btw. it's usefull to have a bit skill on PC's and Laptops)
also press thanks button (or something close :D )if i helped
by
Add a comment
1 Answer
uhh hard one try a bit more search 6x blink should lead you to some error code (why it dosen't work) if not measure the battery, try to change HDD drive (or SSD) and maybe reset the BIOS and look arround the PCB and try to spot some dodgy components (or blown ones)
Add a comment
Add your answer
Manol will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 41
All Time: 6,771
