Guides and support for various television (TV) brands and styles.
9050 Questions View all
Sceptre lcd tv model x322BV no sound, no picture, No signal
I have a Sceptre 32inch LCD TV which after being turned on shows the Sceptre logo on the screen and then turns blue stating no signal on the screen. The tv does not have sound or picture. I was wondering if it was the power supply or the mainboard which is causing the problem. The model is X-322BV-HD.
Score 4
2 Comments
Anytime I press any button on the remote the tv just shuts off buttons on the tv do not respond at all
by
Hi @ allensparalaw,
What is the make and model number of the TV.
Does the power indicator light change colour when you go to turn the TV on?
by
Add a comment
1 Answer
Chosen Solution
Hi,
The power supply must be working as the logo and blue screen and message are appearing. The no signal might be that the TV is not switched to your aerial but rather to one of the other inputs available on your TV e.g. USB, YSBPR HDMI,etc. Just wondering if you get any response when you press the "TV" button on the remote. Try the "Source" button to cycle thru all your inputs. Also check that your aerial lead is plugged in correctly.
Score 1
Add a comment
Add your answer
la23197 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 24
All Time: 8,107
