The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying. Released on March 11th, 2011. Model numbers: A1395, A1396, and A1397.
730 Questions View all
Question Closed
My ipad fell on the ground and than this.
My ipad fell on the ground and than this. The screen is nothing but black, but when i connect in the computer and slowly take the cable out a blue screen appears, I've uploaded a video on youtube where it shows it more clearly.
Add a comment
Chosen Solution
Looks like you have a bad motherboard. It probably was damaged in the drop. Either from the shock of the drop, or maybe a cracked board. Best bet is to have a professional take a look at it for you.
Add a comment
Most Helpful Answer
it can be a bad LCD and can be the lcd flex got disconnected i had fix many of these issues.
Score 1
Add a comment
Its most likely the connection to the motherboard, could be the screen itself. I would suggest having someone look at it and making sure that everything it connected tightly. If that doesn't fix the issue it may be the screen. The professional would be able to tell you.
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 102
