Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Questions View all
After replacing LCD, Inverted colors and unresponsive touch.
Hello,
I recently replaced the LCD and Digitizer on my iPhone 6. On reassembly of the product i found that the screens colors were inverted and in negative form. also the touch on the digitizer was unresponsive. I did some further investigation as i believe it may be the a faulty screen or the plugs not inserted correctly. I tried another screen to rule out the LCD been the issue.
I have found that if i don't plug in the digitizer and only the LCD the colors are fine. soon as i plug the digitizer in the colors change to negative. Could this be a software fault or a fault on the FPC for the digitizer. The phone has not been dropped either.
Appreciate any help you can give
Best regards
Carl
Add a comment
1 Answer
Chosen Solution
Well, inverted color scheme, is a software option for that phone. It is possible to turn that off. However, you need to have a responsive digitizer for that to be accessible. Was the second display assembly touch responsive? Where are you getting your parts from? Have you tried cycling the battery?
Score 1
Add a comment
Add your answer
Carl will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 207
