The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Questions View all
Why won't by tablet charge?
I try to charge my tablet, but nothing happens when I connect my charger. I've tried using my charger on multiple other devices and it works fine, so I know the charger is not the problem. HELP PLEASE!!!
Score 1
Add a comment
Possibly, you need a new battery. First before you think you might want to change out the battery, you want to see if your charger is charging any other of your devices. It could be your charger going bad. You can test your battery if you have a battery tester to see how much juice you have on your battery. If it is not your battery or your charger, it could be your daughter board that is going out. You can change it out. I hope this helps.
Add a comment
Bad charging port is very common on the Tab 4 you can purchase a in line charging port tester for a few dollars it will show if the tablet is taking a charge or not.
Add a comment
Add your answer
Briana Honeycutt will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 16
All Time: 167
