Guides and support for various television (TV) brands and styles.
9049 Questions View all
Why is my screen black?
I've had my Philips LCD 47PFL7432D/37 for 8 years. Never had a problem, then the other day I put on my TV, it was on for several minutes, then it just went black. The sounds still works, and the backlight (ambilight) still work perfectly, but no picture at all.
I've done a little research and I've seen some that say it's the inverter board gone bad, and other that say it's the T-CON board.
Any ideas? Thanks in advance.
1 Comment
i have the same type of tv but mine u can watch for about 30 to 45 mintutes then its goes black plus the left side of the screen is always darker also and its a 48 inch what could be wrong with it please let me know
by
Add a comment
1 Answer
Chosen Solution
Justin, it is possible that you have issues with the power supply, like bad caps etc. After that you may have issues with the main board, and last could be a panels failure. You will have to take the back off and take a look (as well as post some high res images with your question) at the board for some obvious damage. Sure it could be the inverter, but I'd put that on the bottom of my list right there with the T-con board. Let us see and know what you find.
Score 1
Add a comment
Add your answer
Justin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 283
