7.1 megapixel camera by Canon, model SD750.
9 Questions View all
Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
6 Comments
No memory card in my camera
by
Use the camera to reformat the card.
by
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
by
When it says no card what will you firmat bro
by
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
Score 1
4 Comments:
Did you get my last response?
by
I guess not. All I got was that one
by
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
by
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
by
Add a comment
Add your answer
mesarey will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 29
All Time: 4,995
