Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
My proximity sensor doesn't respond
I recently replaced a cracked touch panel/digitizer on an iphone. Everything works, the home button, speaker-everything except the proximity sensor. When you make calls, the the iPhone doesn't go blank, as it should, when you make calls. It's not responsive at all. Has anyone else had this problem?
Score -1
Add a comment
Chosen Solution
check cable no 3 is seated right
Add a comment
If you need to replace it (#3 ribbon), see this:
iPhone 3GS Proximity Sensor Ribbon Replacement
Add a comment
done, but it doesnt still work.
birghtness sensor works, but proximity nope.
Add a comment
Add your answer
AshD will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 8
All Time: 1,222
