You know them, you need them, they move your cursor around. Repair information for your nest of mice.
484 Questions View all
Why doesn't the Num Lock light turn on?
Corsair Vengeance K70 Mouse
My keyboard was doing fine until I noticed a while ago (a couple of days) that the Num Lock light that shows whether the Num Lock is on won't turn on. The Caps Lock and Scroll Lock lights turn on fine. This is a relatively new keyboard (< 1 year) so I don't know what the problem is. The Num Lock function still works.
Score 1
Add a comment
Chosen Solution
The Number lock feature can be enabled in the BIOS settings. Depending on the model of PC you can press F2 when promoted during the initial boot up to take you to the Settings. Scroll through the options and enable it. Hope this helps you.
You can also attempt to move the keyboard to another USB port to see if this also resolves the issue.
Score 2
Add a comment
probaly a bad led
try replacing the led
Add a comment
Add your answer
James Leung will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 42
All Time: 5,211
