Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
121 Questions View all
My 73' mitsubishi WD-73734 has a green blinking light that won't stop
I have a Mitsubishi 73" WD-73734. I replaced the lamp and now the green light won't stop blinking I even pushed the factory reset and it is still blinking.
Score 2
3 Comments
Which green light? The Lamp LED?
by
Blinking green light constantly Flashes tried everything suggested
by
My green light blinks 1 time and slight hesitation and then blinks 2 times what's my code number
by
Add a comment
Most Helpful Answer
sassiekat2004, I'd start with the error code check:
Error Code Operational Check
Note: The TV must be in “Shut Down” and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to “12” No Error.
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The “TIMER LED” flashes denoting a two digit Error Code, or indicating no problem has occurred since the last Initialization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Let us know what if any blink code you get
Score 5
3 Comments:
My green light is blinking 1 time and then slight hesitation and then blinks twice what's my code
by
@Chuck Hensley that is for a WD-73734? which light is blinking?
by
Green light blinks about five times and then the TV turns Off by itself.
by
Add a comment
I have a new projector blud but a black screen
1 Comment:
@c1fc22wnavusui1 What make and model? What were the issues? What do you mean by « new projector »?
by
Add a comment
Add your answer
sassiekat2004 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 29
All Time: 4,847
