1.6 or 1.8 GHz dual-core processor, 2 GB or 4 GB of SDRAM, 64 GB or 128 GB SSD
192 Questions View all
Question Closed
Key doesn't Work after batterychange
I changed my battery according to your excellent site. Works very good but after changing my "right arrow-key" doesn't work.
I tried to fix it again without succes. Do you have any solution?
Thanks!
1 Comment
When did the right arrow key stop working?
by
Add a comment
Most Helpful Answer
Make sure all of the keys work. if the problem is just the one key.
I would pop off the key cap and using a slightly moistened cotton swab (Q-Tip) with a high grade of Isopropyl alcohol (85% or better) clean the key scissor, the keycap & the frame.
Score 2
Add a comment
Try reinserting the battery connection again. This is sometimes a problem with various notebooks.
1 Comment:
Thank you for your suggestion! Unfortunately it didn´t work. I tried doing it again a couple of times, but that didn´t help either. I don't think I did it wrong. It is just the "right arrow"-key. Any other suggestion?
Thanks again!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 65
