Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
water damage, replaced battery, will not charge
My iphone 3g fell in the pool, I dried the phone with hair dryer on cold setting and placed it in a bag of rice for 3 days.
After that I turned it on and it worked fine. But it would not charge anymore. I replaced the battery and it seem to working but I when I tried to charge the phone nothing happen.
Update
I replaced the dock-connector but still not working.
Score -1
3 Comments
Thank you, what is the dock connector/ribbon 4, do I clean it with a soft brush?
How can I get a replacement part?
Thanks again!!
by
parts are available here and so is the guider!iPhone 3G Dock Connector
by
I have the same problem. Battery life was poor so replaced the battery. New battery worked fine but found after it was left charging that it stayed at 12% without improving. Did you ever get a solution to this problem
by
Add a comment
1 Answer
Chosen Solution
check the battery contacts for residue. but it's more likely the dock connector/ribbon 4. clean/reseat or replace
Add a comment
Add your answer
Uschi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 3,278
