Acer Iconia A3 is a 10.1" Android 4.2 Jelly Bean tablet powered by a quad-core Mediatek processor.
11 Questions View all
Question Closed
Update done and it gone off and won't turn back on
I done a systems update on my Acer A3, it switched off straight away and now won't turn back on, please help
Add a comment
This sounds like an operating system boot loader problem. When a device turns on, it gives permission to the operating system (in this case, Android) for a very small number of devices, such as the CPU and the power supply. As the operating system boots up, it requests and receives more and more permissions. When the device does not get boot loader permissions though, it cannot boot. This is something that will have to be resolved through Acer customer support. Hope this helps.
Add a comment
'You Should to reflash it and If you are unable to start the process for your tablet does not answer the Preloader mode, you will need to remove the back cover and disconnect the battery and start the tutorial battery disconnected. Once the tutorial finished, reconnect the battery to load 10min, and then attempt to restart.
The tutorial is :
> http://acer-club.fr/viewtopic.php?f=227&... ==> [TUTO] Unlock Bootloader + Flasher CWM + Root [A3-A10]
__________________________________________________________________________________________________________________
> http://acer-club.fr/viewtopic.php?f=227&... ==> [TUTO]Unbrick/flasher le dernier firmware JB [A3-A10/A3-A11]
___________________________________________________________________________________________________________________
> & all in ==> http://forum.xda-developers.com/android/...
> & http://forum.xda-developers.com/showthre...
____________________________________________________________________________________________________________________
A3-A10 | JB | http://is.gd/fa10_42 | c663e76b16a930f10dff84510a79b740 | AV052_A3-A10_RV05RC01_WW_GEN1
| A3-A10 | KK | http://cutt.us/gwSU | a8927856a6d655adb2ea9d4807fc63be | AV0K0_A3-A10_RV05RC03_WW_GEN1
| A3-A11 | JB | http://is.gd/fa11_42 | 0d828c175073896adef35015c03617c7 | AV052_A3-A11_RV01RC12_WW_GEN1
| A3-A11 | KK | http://cutt.us/gJzLe | b1f610a1b07b3c0b120d103318508bca | AV0K0_A3-A11_RV04RC05_WW_GEN1
| A3-A11 | KK | http://cutt.us/jjOp | 59705bb7d9bb1d7530fee641aeaa5bbf | AV0K0_A3-A11_RV04RC07_WW_GEN1
♥ Good Luck ♥
Add a comment
it's too easy Guys .
-If you are unable to start the process for your tablet does not answer the Preloader mode, you need to remove the back cover and disconnect the battery and start the tutorial battery disconnected.
Once the tutorial finished, reconnect the battery. put in charge 10 min and then attempt to restart.
1- remove the back cover.
2- disconnect the battery.
3- reconnect the battery.
4- put in charge 10 min.
5- attempt to restart.
GOOD LUCK
[RYAN KHENNOUCI]
1 Comment:
Please make antoher guide the website is not available anymore
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 553
