Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
My battery won't charge it shows the charging symbol but percentage do
My iPhone won't charge well the percentage doesn't work it shows the little lightning bolt and stuff but instantly dies I know it ain't the charger and I know it ain't water damaged I don't think it would be the battery and I have it tooken apart and everything connected what could it be in not sure if I have a 4 or 4s I never use siri or voice talk this just happened last night any help I'll try I'm gonna try a battery when I get home but I'm at school
Add a comment
Most Helpful Answer
It does sound like a battery issue to me. You need to figure out if you have the 4 or 4S since they are different batteries. If you have the original back cover still on your phone there is a model number listed on the back. It will start with the letter A followed by 4 numbers (A1429 - iPhone 4 CDMA / A1332 - iPhone 4 GSM / A1387 - iPhone 4S)
Score 2
Add a comment
Chandler Lake how do you "know it ain't the charger and I know it ain't water damaged I don't think it would be the battery"? I'd try a new cable, different charger then a new battery. If that is not going to give you proper results, replace the dock connector. If after that it still will not charge check the components around the battery connector and make sure that the connector is properly installed. If your phone comes on with a fresh battery but does not charge, it is possible that you have a bad power management IC. That is a BGA IC and needs special tools and skills to replace. It is also possible that you have a failed charging coil or "USB fuses". You will at least need a multimeter to check those components for continuity.
So, I'd go ahead and start with a battery just like TechyGirl suggests .......
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,076
