My speaker isn't working.
I can't play audio out loud through the speakers. It works fine through the head phones. What is causing this?
Several things could be preventing your speakers from playing audio out loud. First, make sure that your volume is not turned all the way down. Turn the volume up using the [+] button on the side of the tablet. If the volume buttons are broken, you can also go to Settings > Sound > Volume to adjust the speaker volume.
If you still can't play volume out loud, it could be an issue with the tablet. Try doing a factory reset. Instructions on how to do the reset can be found here: Trio Stealth G4 Troubleshooting.
If the problem is still not fixed, the speakers are most likely broken. Consider replacing the speakers.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 86
