Originally released in 2006, the NeatDesk is a desktop document scanner with ADF and full-duplex features. The early revision has model number "ADF-070108" and the newer revision is model "ND-1000."
37 Questions View all
My scanner does not respond when paper is inserted.
My scanner powers up but does not respond when paper is inserted. What's the problem and how do I fix it? Thanks!
Score 2
Add a comment
Most Helpful Answer
Make sure paper is aligned properly. The rolls should turn trying to feed paper when you click on scan. If they are not rolling make sure communication is active between computer and scanner.
Score 2
1 Comment:
Great answer - thanks!
by
Add a comment
The board in the door needs replaced or the plastic fingers are broke
Score 1
Add a comment
My scanner's lights are green at first when I try to scan. It makes a buzzing noise but the paper does not move. Then the lights start flashing red. It appears there is communication, but the scanner is malfunctioning. What do I try from here?
Add a comment
Add your answer
Bobby D will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 2,029
