Why won't my memory card work?
I have the memory card inserted into the camera, but it is telling me that there is not a memory card in the camera. How can I fix this?
Gently remove your SD card with a pair of tweezers to avoid further damage. When you insert the memory card, does it click into place? If not, there might be something small blocking the SD card contact. Carefully turn your camera upside down to remove any loose debris. Make sure you are using the correct memory card size for your camera.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 720
