Dishwasher won't drain, water backing up...
I have a Frigidaire Gallery Dishwasher that is only a couple years old.
Model #LGBD2435NW0A All the sudden there is standing water in the bottom of the washer. I have done a decent amount of research on it, and am stumped.
It is out of warranty according to Frigidaire. I have somewhat recently 6 months ago, installed a new garbage disposal that it is connected to, however it has worked fine for 6+months so I'm confident that isn't the issue. I troubleshooted the washer using a video on youtube and put it in diagnostic mode. When I go to the drain setting, I hear a noise, sort of like gears turning or grinding/clicking but nothing happens. I let it stay on this mode for a while and it never drained.
Help please!!
Update (09/17/2015)
Here are some pictures to help. This is after I manually removed most of the water with a cup, and after I took the filter out and cleaned it(wasn't that bad).
Score 2
Add a comment
1 Answer
Most Helpful Answer
Matt Collier, sounds like either a bad drain valve or a bad drain pump. Neither one of those can be repaired but must be replaced.
#60 for the pump.
Score 1
Add a comment
Add your answer
Matt Collier will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 3,642
