iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Click wheel scrolls, but buttons don't work. Why? Help needed.
My ipod has previously been exposed to water in the form of rain drops, which caused one of my "next" buttons to stop working. That had been going on for several months. Recently, All other buttons have stopped working. I cant even turn the device off. I think it may be due to the fact that I used the device with wet hands. It could potentially be something else, who knows? None of the reset techniques that I have used worked. I can scroll and the screen which shows album covers like a slide show is running. It seems as though this is the only part of the Ipod that isn't working. I'm too chicken to try taking it apart.
How can I fix it?
Score -1
Add a comment
Chosen Solution
the click wheel and the buttons are 2 different things
so one can be dead while the other one works flawlessly
but the only chance to fix this is to open the ipod and to clean the buttons and the logicboard with isopropyl alcohol (>90%) and a soft paintbrush. it's possible that you also have to "open" the buttons - it's only a metal "foil" that might be shorted
since you didn't provide the info what ipod you have, a can't give you the link to the correct disassembly guide
EDIT
here are the guides:
there are 2 guides you should use. the click wheel button guide and the logicboard guide - step 34 shows the buttons on the logic board
iPod Classic Click Wheel Button Image
Guide
iPod Classic Click Wheel Button Replacement
Difficulty:
Very difficult
30 minutes - 1 hour
iPod Classic Logic Board Image
Guide
iPod Classic Logic Board Replacement
Difficulty:
Very difficult
1 - 2 hours
1 Comment:
It's a 6th generation Ipod classic. Thanks for being helpful!
by
Add a comment
Hey all!
I like to tinker on iPods from time to time and I was having the same problem. I noticed that I had unfortunately bent the ribbon that connects the scroll wheel to the logic board so it was no longer straight. After inserting scroll wheel into connector and securing it down i applied pressure to back of logic board. All of sudden buttons started working again. Scroll wheel works and now buttons work! Success! In essence the scroll wheel was the culprit.
Add a comment
Add your answer
Maria Sedler will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 3,669
