The third iteration of the 10.1 inch Galaxy Tab tablet.
126 Questions View all
Replaced the usb port but still not working.
I ordered the correct piece and replaced. However, It is not charging.
So did I do something wrong? Can I test it somehow? Or is the battery not charging because I waited 2 months to replace the usb port?
Any help would be appreciated.
Tricia
Score 1
1 Comment:
I still have the same problem after having the charging port replaced and tested by a professional. My tablet has caused 4 micro usb charging cords to malfunction. Is there a problem with my motherboard or something, and can it be repaired?
by
Add a comment
1 Answer
That could be a defective charging port. It sounds like an accident ready to happen. Something must be wrong with the power rails causing a short somewhere. If you feel lucky then you could try a new charging port again and se if it helps. However, I would suggest that you take it to someone who can measure the power rails on the motherboard.
Add a comment
Add your answer
tricia will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 184
