Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Question Closed
Battery can't hold charge and reboot loop after battery change.
Hi guys,
First, thanks for the help. I just bought a battery for my IPhone 3GS (can't remember if it was through you or another company). The battery model is APN: 616-0431.
Like the title says, the new battery can't hold a charge and the phone is stock in a reboot loop (white apple, then black screen, again and again). If I unplug it, it just die. After the amazing result of my battery swap, I though maybe I did something wrong. So I open the phone again, checked all the connection I touched, nothing seems armed.
I looked through your forum and I notice that maybe it is the battery model. That I should have a battery with APN over 0435. What do you think? If it is the problem, how can I be sure that the next battery will be ok? Cause if you look on the image of the battery you sell, it's APN is 0431.
Thanks!
Matthieu
Update (08/31/2015)
Ok.. But now, how can I be sure the next battery I buy will be new enough to work?
Add a comment
Matthieu, these should be the compatible batteries: 616-0431, 616-0432, 616-0433, 616-0434, and 616-0435. So it could be the battery itself. After all, the battery may be new to you but may already be years old. I'd replace it once more
1 Comment:
by
Add a comment
Did you try a hard reset of the iPhone? I had a similar issue when I replaced a battery on a 3Gs. Open iTunes, plug iphone into laptop/pc, if it doesn't start automatically, power it on an perform a hard reset, iTunes should pick it up in recovery mode and from there you can recover the phone from it's boot loop.
Hope this helps.
Add a comment
This is a scam... Don't buy battery from the website
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 104
