Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
23 Questions View all
How do I get passed security pattern screen ( forgot pattern)
Security issue with pattern screen
Score 8
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
Try to do a factory reset and let me know if it helps.
Have the tablet powered off first and make sure you have more than 50% charge on the battery. Boot into recovery mode by pressing and holding the volume up and power buttons. At the RCA logo screen, let go of the volume up button and you should next see an android image. Press and hold the power button and tap the volume up button once more and you will be brought to the recovery mode menu. From here, you will need to use your volume up and down buttons to scroll and navigate to the wipe data/factory reset option and use the power button to confirm. When the process is done, go ahead and reboot and your tablet will be set to factory original settings.
Score 4
Comments:
will i lose any of my stuff
by
Add a comment
There is a reset button on the back. Press that. WARNING!!!!! It will shut down everything so there will be nothing left on it!!!
Score 1
Add a comment
I need help i can't get in mine I don't have any locks it would not even let me swipe up to get in.( sorry if I missed spell a word I'm only 11)
Add a comment
Add your answer
Bailey Hawkins will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 8
Past 30 Days: 39
All Time: 845
