Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 Questions View all
Question Closed
My GPS & Wifi signal are very low after water drop
Hello there,
I drop a bottle of water on my oneplus one, since then, my gps can't fix and my wifi only find network if i'm less than 1meter of the router.
I tear it down, clean everything, but still no luck, do you think the antenna in the backcase may be the problem?
Thanks.
Add a comment
1 Answer
Hello
Mobile'll swim the basic power is no major damage
Note that one plus phones GPS & WIFI antenna is in the back cover, based on your description I think it is the back cover of the antenna appears oxidation or corrosion, you can try to use alcohol / eraser to clean; of course, do not forget to clean up PCB on contacts: )
I have a another idea is that you can replace a cover, just to change a set of wood or other materials ~
Add a comment
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 315
