Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
I change the Board, and now I can't do Restore error 53
I have a iphone 6 with damaged Board and i took another Board in good conditions from other iphones 6 and i installed it. Everything it works GREAT.
Some technician told me that when a iphone 6 Board or the Home Button is changed, the TOUCH ID will stop working and i know it and that is not a problem for me, im not interested in that.
But when a go to my laptop and try to Restore the phone in itunes i get an error 53 …why??? There is a solution for this problem???
Add a comment
1 Answer
Chosen Solution
Yes, there is a solution if you did not damage anything during the transfer.
The new board that you installed came from a phone. It must also have had a home button with it. This home button must be transferred with the board as well. Then you restore again.
If you cannot find and transfer the home button that came (or was originally paired with the new board), then your phone will remain stuck in error 53.
Score 1
1 Comment:
Yes i have the other iphone where i pull the Board out. But the LCD Display is crack and broke and the Home Buttom is lost. Could i only put the LCD without the Home Button to try if works???
by
Add a comment
Add your answer
Papo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 116
