Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Question Closed
How to repair crackling noise when using headphone jack (left)?
whenever I use my headphone jack through whatever external device there is a crackling noise in the left 'output'. What parts do I need to repair/replace to solve this problem?
many thanks,
flora
Add a comment
1 Answer
Chosen Solution
You could have a bad jack which is not easy to replace. You could have a loose connection on the Audio board, or lastly, the Audio board is bad.
Here's the IFIXIT to get to the Audio board: iMac Intel 20" EMC 2133 and 2210 Audio Board Replacement. Locate the jack header and make a test jack to plug in to the header. Does the problem go away? Does reseating the jack connection fix it? If both of these actions fail its time to replace the audio board.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,649
