What do I do when only half of my LCD is working?
When my LCD is on only half of the image is showing on the screen.
It sounds like the cable connection is lose. Either that, or your screen is damaged and needs to be replaced. You should try opening your tablet, and removing the screen. Reattach the screen and make sure all the cables are attached to the motherboard. If the problem persists than you will have to replace the LCD. Try using the guide below.
This could be caused by 2 problems.
1. If you replaced the LCD it could be the connectors arent fully plugged in.
2. The LCD is going bad and you need to replace it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 271
