A collection of guides and support to help with washer repair.
3473 Questions View all
Question Closed
Maytag washer LAT9200AAW Won't agitate, spin, or drain.
The washer will fill and after that simply stops. I tried changing to spin and cycling the power. The agitator never starts, and the drum never drains.
6 Comments
talveren, this could be something as simple as the door lid switch to something as bad as a burned out motor. What have you checked? This is a belt driven agitator etc. have you taken a look underneath to see what's going on?
by
I looked at the belts, and they appear ok. I'd guess they got replaced sometime before we bought it because there's no rot at all and the tensions seem correct. I took out the switch assembly, and we're going to test the components tomorrow with a multi meter. I've looked over the pump, but haven't taken it apart since I don't think a failed pump would keep the agitator from working. It seems to be fine.
by
You are right. the pump would not. It could easily be the lid switch.
by
If you are interested in the service manual for the Maytag LAT series washer, send me an email. My address is on my members page. Just click on my avatar
by
components for the switch assembly all test fine. I'm right in thinking it's the drive motor now aren't I?
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
talveren, start off by checking the belts. Let us know if you have basic tools to work on your washer so we can provide you with a bit more help.
Update
Washer will not spin or agitate
No power to washer
Reset breaker or fuse
Lid Switch
Check for continuity across the lid switch Motor
Check for continuity from control board output to motor run relay and from relay to the motor
Control Board
Perform motor check
Motor run relay
Put washer into spin and check for relay contact closure
Score 1
1 Comment:
The belts appear to be ok.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,996
