Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Questions View all
Question Closed
It died and won't wake up, will kissing it work?
Hello! Alright, here's the story:
My iPad mini (16 gig) was at 2% so I plugged it in before i went to work. I was at work about five hours, so once I got home I wanted to get on my mini (because what else would I do? Go outside?) but it wouldn't wake up at all! I even let it charge for a full day and night. I tried holding the power button (at intervals of two, three, five, seven, ten, and fifteen seconds) that did nothing. Tried holding the home button (same intervals) didn't work. Tried holding both (again, same intervals) didn't work. I am willing to lose the memory on my mini to get it to work again, even if a backup doesn't work I'm fine with that. I just want it to work again! Would sending it to you to diagnose cost a lot (not including repairs, because I really couldn't repair it, too many intricacies and tiny things i can break) and would repair costs be a lot? Also, please help!
2 Comments
ifixit does not do repairs. Is your iPad being recognized by your computer.?
by
not at all, it's like it doesn't exist to it!
by
Add a comment
Most Helpful Answer
James McCann try to see if it goes into recovery mode. Press and hold the home button while connecting the USB cable from your computer to the iPad. Continue holding the Home button until you see " Connect to iTunes" then release the home button. iTunes should now see your iPad mini and report that it found an iPod in recovery mode.
Score 1
1 Comment:
It didn't work, I just tried it. Or am I supposed to hold it down for more than a minute?
by
Add a comment
Hi James,
Unless you're iPrince Charming, kissing will not cut it.
First, I need to understand a few things:
- When you press on the power button or home button, do you see anything on the screen? Such as "empty battery + cable"?
- When you plug in the charging cable, do you see the "empty/red" battery, and the "cable" is now gone?
- Have you tried a different known good wall charger + cable?
I'll edit and add to this answer as we go along.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 114
