Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2397 Questions View all
Question Closed
iPhone 4 Died, no water damage!
I have an iphone 4 and it does not powers on. No water damage on this phone indicators are clean. The phone is completely dead, itunes does not recognize it. Tricks like push power button and home button together does not work. No sigh of life in this phone even if i charge it all day. The motherboard is so clean, looks perfect but it does not work. I think its the power ic chip. Can someone tell me how to check this chip?
Add a comment
1 Answer
hi John,
I had the same problem.
i checked the power connector with a multimeter. ( remove the battery, connect the iphone to an adapter (charge it) and see with the multimeter.) if you have power the problem will be at the main board ( or battery).
if not try with another cable/adapter.
i replaced the motherboard, you can find these from other broken iphone's ...
i hope it will work out for you.
good luck
greetz,
Kevin
6 Comments:
Thank you so much Kevin, i will do this and i will reply!
by
Ok, so i remove the battery and i put an iphone charging adapter. Then where i put the multimeter points to check the motherboard?
by
i'm sorry it took so long but i was on a long vacation, do you still have the problem ?
by
It was the battery, but please if you want tell me where to put the multimeter points to check the power?
by
ok, well i will try to make a picture en post it here. or you can try it yourself : see this youtube movie how to test the battery https://www.youtube.com/watch?v=msamRT28... and to test the connection on the mainboard ( power up the iphone without the battery ) i did'nt found a youtube movie but it is about the same. good luck, if it doesnt work , get back to me and i will try to make pictures en post it.
by
Show 1 more comment
Add a comment
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 105
