Repair guides and support for cars and trucks by Toyota Motor Corporation.
983 Questions View all
2005 Toyota Prius Check engine light on, mechanic says code is P01121
Mechanic says this code, P01121, means "coolant flow control valve." I have not fixed this. Does anyone
  1. know about a reader for the OBDII port (mechanic charged a lot for reading the code)
  2. know how to interpret these codes
  3. know if "coolant flow control valve" is serious? the car works fine, but the check engine light is almost always illuminated
1 Comment
Had same problem. 2005 Prius. Fixed under recall. 2nd time fixed myself. Check "priuschat.com" for instructions.
by
Add a comment
1 Answer
Chosen Solution
Try this it may help
https://www.youtube.com/watch?v=_JHNNBbh...
Score 2
Add a comment
Add your answer
Bruce W will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,907
