The first generation of the Chevrolet Equinox, a crossover SUV from Chevrolet based on General Motors' Theta platform.
114 Questions View all
3.6 litreengine oil leak@timing chain cover
How hard is it to pull the Harmonic balancer , Any specialty tools needed. I have over 25 yrs. experience as a mechanic .I have not worked on a 3.6 before this is charity work .Any help would be appreciated.
Add a comment
1 Answer
Chosen Solution
Remove the bolt holding the balancer to the crank . A normal gear puller will work but don't pull from the outer ring as this can damage the rubber try to get on to the inner edge right next to the shaft. should pop right off. Good luck with the Job
Score 1
Add a comment
Add your answer
afn5300 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 185
