The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
466 Questions View all
PS3 fan still loud after thermal paste + fan replacement
I have a 250gb ps3 slim
whenever i used to play a game for 10 minutes the fan used to get really loud so i changed the fan to a new one and replaced the thermal compound on the cpu and gpu , i put it back together but the fan still gets really loud , I DONT KNOW WHAT THE PROBLEM IS NOW someone plz help me , when the ps3 is loud the cpu temp is like 70 degrees and the rsx temp is 60 degrees
PLEASE HELP ME
Add a comment
1 Answer
Chosen Solution
The fan runs loud because of the heat . When you put in the new fan did you clean the heat sink ? Are all the vents clear the fan needs to be able to exhaust is the fan installed right way up is it blowing in the right direction.after reinstalling the cpu and gpu did you get them securely fasted down . There needs to be solid contact for heat to travel efficiently. Just some things to check hope it helps
Score 2
1 Comment:
i did all of that but still the fan goes crazy , i read online and it might be because the paste under the cpu ihs has dried and i have to replace it , should i do it?
by
Add a comment
Add your answer
yousef06 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,353
