The Dell Inspiron 1500 is a laptop computer designed for home-entertainment with a narrow border for a wider viewing area.
16 Questions View all
Question Closed
laptop cannot start pressing power button, the power light once
I have a Dell inspiron 1501 and possibly some power purge due to connection with some external usb devices, it no longer can turn on pressing the power button. The battery has died and have been removed for a long time so I depend on the ac plug charger/adapter. When I press the power button, its LED light turns on once and then off and nothing seen on the screen. I open the case and see that the power button is that some kind of mechanical push switch on a small piece of pcb. Is that any way I can turn on the laptop by shorting somewhere?
Thanks
1 Comment
I opened the panel of the power button of Inspiron 1501 and use some wires to short the terminals near the power button and it works like what I press the power button as before but do not show anything on screen or turn on the laptop. Will there any mechanism that I can bypass the power button? You can find video how the 1501 looks when disassemble on youtube. It is a pcb.
by
Add a comment
Most Helpful Answer
Hey sunny, I believe that you might have a faulty CMOS battery. Follow this and see if this solves the issue.
-Let me know how it goes.
-Please accept this as the answer if it answered the question.
Score 1
3 Comments:
You can also check the power jack, if it is loose you might have to replace it.
by
No. Replacing the CMOS does not fixed the problem.
by
I can see the LED flash once when the power button is pressed. Also I leave the power jack untouched after I plugged it in. So this probably not the loose problem you mentioned.
by
Add a comment
go to https://www.youtube.com/watch?v=UbtdwafW...
Add a comment
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 8
All Time: 1,725
