No picture or sound, just green light on front
Toshiba TV 40RV525U picture locked up and slowly faded away, now nothing but a green power light
Score 1
Comments:
this could be a power supply issue as well as a main board issue. Do you have the back of the unit already? Do you have a multimeter? Are you comfortable measuring some voltages? Post some images of all the boards with your question so we can see what you see. To post images follow this guide
by
AS I signed in with my email the blue line stating no video input flashed across the screen. Changed the input to HDMI2 where I had the cable hooked up to my yamaha receiver which is getting signal via HDMI from set top box. I will now attempt factory reset! Just turned it back on . Havd TOSHIBA & Green LED lit up. Now just came up fuzz and initial setup menu. I will run with it and see what happens. If you have more info or ? please contact jamietollefson@gmail.com Bye.
by
Add a comment
